2024 Technology Preview Program
Wishes
A simple way to reduce the number of nodes in a poly line
Markitecture
Creating a mesh from the surveyor’s file does not always give the desired results since often the xyz points are few and far between, resulting in a rather rough terrain with large triangles. This means we need to create the mesh "old school", contour line by contour line.  Those lines often have way too many nodes, creating an overly complex mesh.
The usual process is to first use Magic Wand to create a spline from the overly complex poly line, then set the Magic Wand settings for conversion back to a poly line with fewer nodes.  This has to be done individually on every contour line of the terrain.
User request:  It would be great if you offered a simple tool that just did that node reduction in one step, especially if it would do so on all selected poly lines in one step.  That way, we could simplify an imported surveyor file of contour lines in one simple step before creating a mesh. It would also be great if doing so would not add nodes along lengths already exceeding the magic wand settings, only reduce clusters of nodes that are closer than that setting.
3 REPLIES 3
F Barradas
Just as a reference for developers, SketchUp has a very straightforward plugin called Simplify Contours that does exactly that.
Thank you.  Good workaround for those who also use SketchUp.  Personally, I line to keep my work in Archicad and appreciate when the developers adopt new capabilities.
Best regards,
Mark
Hi Mark, I totally agree to keep the workflow within Archicad! My post was to support your idea showing to Graphisoft's developers an example of how this tool could be simple. I hope they add this feature soon!
