Wishes
A wish for --- Text Formatting in Property Expressions
gdford
I think text formatting options should be available in property expressions.
For Example:
CONCAT ( {Property:INT-SYS | Equipment/CatTag}, "-", {Property:INT-SYS | Equipment/TypeTag}, ".", {Property:General Parameters/Element ID} )
Here three properties are concatenated together.
It looks like this in a label:
      EQ-01.94
I would like it to look like this:
      EQ-01.94
if we had basic text formatting rules available in the expressions I could do this.
.... and yes I know how to hack this by assembling this all in a label instead of using an expression. Using expressions saves time in the long run because changing the expression changes hundreds of labels and I can use the result of the expression in a schedule!! I can't hack that together in a schedule.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
0 REPLIES 0
