Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Wishes
A27 - Transfer Custom Properties to a Morph
gdford
Early Release A-27
Sample and Inject custom properties
When you sample a morph and inject another morph custom properties are not included in the transfer. This has been a know issue for several years.. Please fix this!!
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
2 REPLIES 2
This works for me fine in both Ac26 and Ac27.
I wonder which Element Transfer Settings are you using? I was using the "Exclude ID/Layer" Element Transfer Setting and it worked fine. I have set 3 Properties of a Morph to custom values, and when I used ALT-clicked to pick up element settings, and used CTRL-ALT-clicked to transfer those settings to another morph, the custom Property values transfered as well for me.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
That is interesting - I will retest - Now one thing that was likely different is that my morph had no thickness. Could that make a difference?
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
