2024 Technology Preview Program
Wishes
SOLVED!
Ability to assign keyboard shortcuts to frequently used tools
PennyDB
Modelling with one hand on the mouse (in the model) and the other on the keyboard (typing commands) is much quicker than mouse selection only.  BUT please pay attention to the size of peoples hands!  I have small lady hands and the combos CTRL +7 (for story settings) and ALT+7 for (save view) are impossible to achieve one-handed, as are many of the three-key combos, especially if they use both the CRTL and SHIFT key at the same time.
Dexterity decreases with age, and Graphisoft should be thinking about inclusiveness!
1 ACCEPTED SOLUTION
Solution
David Maudlin
PennyDB:
Go to Work Environment > Shortcut Schemes > Keyboard Shortcuts and assign your preferred shortcuts to these commands. Save your Shortcut Scheme and assign it to your Work Environment profile. You can also export schemes for saving and importing to other computers.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
3 REPLIES 3
Solution
David Maudlin
PennyDB:
David
PennyDB
Thanks David, that has really helped.  Sometimes these things are totally buried and you need a person in the know to tell you!
PennyDB:
Yes, there are too many features to know the entire application.
David
