2024 Technology Preview Program
Wishes
About lines that disappear when Zone borders overlap
LeeJaeYoung
There are cases in which the building in the back is visible in the cross section and the back of the room is not visible.
So I use zone. However, the border of the zone covers the wall finish line. And it seems that this happens a lot.
The line of the part overlapping with the line of the zone is not seen together.
It would be nice if the zone could be seen except for overlapping with the wall in the cross section.
in section
When selecting a zone
It is a way of expression. We use it like this because there are times when we need to get rid of the overlapping of letters and doors in the room.
We also know that if you see a thick line behind it, it's okay.
However, these days, this is a question because I do not see the printed drawing, but rather the archicad drawing.
1. I don't know why it is expressed as net in cross section even though it is set to cross.
AC27 on window 11
3 REPLIES 3
ryejuan
have you tried turning this on?
In the end what is your Objective?
ArchiCAD 9 onwards
LeeJaeYoung
yes i tried it
And I'm talking about cross-sections.
This phenomenon is seen when the border lines overlap in several places.
That's why I want an invisible (non-counting) line 0.
AC27 on window 11
ryejuan
have you tried the display order?
ArchiCAD 9 onwards
