2024 Technology Preview Program
Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Add the ability to 'Add Change to Selected Layouts'.
It would be great if an option were added to add a selected change to multiple selected layouts at one time. We can currently select a Change and apply it to the currently open Layout. We change drawing status throughout the lifecycle of the project from 'Planning' to 'Tender' to 'Contract' etc and these are often the only changes and need to be identified in the revision history and generally affects all the layouts.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.1
macOS Sonoma (14.5)
4 REPLIES 4
KenMcN
Sorry if I’m wrong about this, can’t check just now, but can’t you select several layouts in the navigator, then go into Settings and add a revision? This is then applied to all selected layouts. At least I think that’s what happens…
Kenny
V25 & 26 (fully patched); Mac Ventura, MacBook Pro M1 Max
I’m not sure about that. I’ll certainly have a look.
Lee Hankins
macOS Sonoma (14.5)
Just checked and it does work, even if the layouts are on different revisions it will increment them by one. Let me know if you can get it to work for you as well.
It works!!! Thanks for that. Wish granted 😃
Lee Hankins
macOS Sonoma (14.5)
