2023-09-26 10:19 AM
Hi there,
I would like to be able put "end of the line text" to expression in properties. Basically Enter at the end of the line.
The reason is simple. When making schedule for eg. windows/doors, I want to merge all properties into one column. It is a standard from the firm I work in.
The only way how to visibly divide the text now is either input separator (eg ";") or use tabulator (with this I am able to make the text jump on next line in most of the cases but not every time).
Kind regards
Karel
