Read more
Wishes
SOLVED!
An easy one: Visible Elements in Trace & Reference
Ricardo Lopez
Hi Archicad's elves,
Wouldn't it be more logical for Visible Elements option to be in the main menu of Trace & reference tool.
It is quite hidden now, don't you think?
It should not be so disturbing for you to change that little thing.
Pleeeease...
Thank you!
Regards.
M. Arch. Ricardo López
AC17-27 SPA+INT | Windows 11 | MSI WE75 9TK, 32GB, Nvidia Quadro RTX 3000
1 ACCEPTED SOLUTION
Solution
The problem is, it is not just a command, it is a pop out palette.
And because it is not an independent palette (you can’t open it on its own), it can’t be opened from a menu item.
1 REPLY 1
Solution
