Wishes
Archicad Export FBX Selection
Vu-205-BS
In AC 27, I can't export FBX only selection model . I need this function.
As you can see in the below picture. In AC 23 with addon "export FBX for TW" that can export FBX selection model.
2 REPLIES 2
Until this wish is implemented:
Can you display only the desired elements in 3D (select them in 3D and use the "Show Selection" command of context menu) and then export as FBX?
2x28" (2560x1440), WIN10 PRO ENG, Ac20-Ac27
Loving Archicad since 1995
I knew this way that show isolate selection.
But it don't enough with me.
Thank you.
