Wishes
Attribute Update Rules: Layers
It would be nice to have the capability of controlling layers via "drawing selection settings" like we once did in plotmaker 9's "drawing settings" under attribute update rules.
We have pen and scale control under drawing selection settings (which is great) but not layer control. I'm currently on AC11 so I don't know if this feature has been added to the current version.
3 REPLIES 3
You have to understand term:"VIEW" in AC. - All You need is there - but You have to control Yourself to avoid "custom" or "user" setting in all possible choices under the view settings menu.
Best Regards,
Piotr
Best Regards,
Piotr
@Piotr: Thanks for the comment. Obviously yes, controlling everything under View Settings is good practice and is something I take seriously. My point is, having to create a view with its own layer settings or even custom is overkill for a view that is being used very little if not only once or temporarily throughout the span of the project. So having the option to control layers via "drawing selection settings" can come very handy and speed up production in some cases.
Erika Epstein
Take the time to set up more views. It really isn't much and this is the solution. Even with layer control on drawings, you still want to save that view
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Learn and get certified!
