3 weeks ago
- last edited
3 weeks ago
by
Hello everyone,
I am seeing that when wanting to send the Base Quantities of the decomposed elements (complex and composite profiles),
it is necessary to map them manually,
this is somewhat tedious for ongoing projects and that their variations in their quantities are needed by openings, as well for compliance with the IFC standard, since each Base Quantities in each class must be mapped in IFC2x4 and the same as in IFC4.
Would it be possible to add this parameter automatically to make it easier to comply with the IFC standard?
Thank you for reading. Greetings
Sincerely Abraham Smith
