Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Wishes
Automatically Find X, Y and ZZYZX extents of objects.
Jarrod Phillips
It would be great to be able to call an object's overall dimensions for use in the A, B and ZZYZX parameters instead of having to calculate it manually. The "hotspots on bounding box" option is able to pull this information from somewhere. Any chance Graphisoft could make this data available for use in the object's parameters?
Jarrod
BIM Manager | Graduate of Architecture
Fulton Trotter Architects - Sydney, Australia
Archicad 15 - 27
0 REPLIES 0
