2024 Technology Preview Program
Wishes
Better ways to set Intersection numbers
DaiG
If I want to change the intersection number for a Layer, I have to make that change for every Layer Combination individually. It's a pain!
Could we have an option to change a Layer's intersection number for all Layer Combos? (and then optionally to make further adjustments for specific Layer Combos, though I'm not sure I have ever found a need for that).
1 REPLY 1
Eduardo Rolon
You can edit all at the same time using Attribute Manager instead of the regular Layer Palette.
Same applies to On/Off, Lock/Unlock, Solid/Wireframe
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
