Read more
Wishes
CI Door empty opening - Wall end closure
Danny5
Hi Everyone,
I was wondering if anyone has a solution to fix the empty opening to have a wall end, similar when using the wall end tool, but is there a setting inside the tool that fixes this problem? I guess you can add a 1 mm frame, but I was wondering if someone has a better solution.
I am also using the CI door tool.
Thanks.
Screen Shot 2023-08-08 at 3.47.12 pm.pngScreen Shot 2023-08-08 at 3.49.00 pm.png
0 REPLIES 0
