Wishes
COVER FILL FOR WALLS & ORIGIN FOR STAIR MATERIAL/ SURFACE
Travis Petersen
1. Would be great if we had a cover fill for walls. I have a low level wall that is tiled, however i cannot show the tile pattern as a slab does (similarly plaster hatch etc). typing this i think it would be possible to show this with a symbolic cut - building material with a tile pattern, however setting custom origin may be an issue, also complex with composites...
2. With-in AC 21 stair, I cannot set a custom origin for the surface used (as well as plan) i.e. continuous tile line from terrace, to follow through stair
2 REPLIES 2
Set your stair to end with a riser.
Adjust the end connection if necessary to allow for the floor slab and bring the slab right up to the riser.
It still may not match the pattern in the treads but at least the top will all be one slab.
I have no suggestion for the wall in plan other than adding a separate fill.
In 3D you can align textures.
Leire Bilbao
"1. Would be great if we had a cover fill for walls. I have a low level wall that is tiled, however i cannot show the tile pattern as a slab does (similarly plaster hatch etc). typing this i think it would be possible to show this with a symbolic cut - building material with a tile pattern, however setting custom origin may be an issue, also complex with composites..."
I would love that too... And beams when seen from top as well
Learn and get certified!
