Read more
Wishes
Can these things please happen in next realease of Archicad?
Calle
Ctrl-7 Story Settings
If you press enter, do NOT close this dialogue window. Just let the input number for any height be confirmed. Just like Excel.
If you press escape, because you are entering a number in the wrong elevation or whatever reason you want to stop typing: Do NOT close the dialogue window and discard every change you have put in. Please have a popup that ask 'Yes, discard' or 'Cancel, continue editing'.  Make it behave like Excel. IT is easy.
If able to add a simple section visualization of the heights. Where you also can drag the heights up or down.
0 REPLIES 0
