Wishes
Changes / Transmittals / Issues / Revision system change plea #1
Being my first post for this, I am going to hint at the confusing terminology of items in this system for the US user (wink-wink) but I am not going to describe it unless you really want a novel...
This being said, here is my first proposal:
Since at the time of archiving changes, we are asked to either keep or delete the markers of the archived changes, and these are global changes that seem to apply to disparaged change on multiple sheets, how about introducing at least one more option that says "Keep markers and hide clouds", which is the most used method on this side of the Atlantic...
Alternatively, maybe you can allow me to select all the instances of all selected changes found by selecting "Find Linked Markers" and allow us to manage the marker settings in bulk, instead of going layout by layout...
All is suggested here is a method to globally hide the clouds of transmitted changes so only the last issue set could be visible. (see what I did here with the terminology? wink-wink)
AC 7-26 (current 25/26)
iMac 3.6 Ghz 10Core Intel Core i9 / 12b GB / AMD Radeon Pro 5700 XT 16 GB / Ventura 13.4
https://globularcreative.wixsite.com/home
1 REPLY 1
Mods, can you move this to Wishlist? I messed up again ....Thank you!!!
Learn and get certified!
