2024 Technology Preview Program
Wishes
Choose the reference level of roofs withe the same options as slabs.
Tinou
Hello,
Why is it not possible to choose a reference level for roofs with the same options as slab reference ?
(Bottom, bottom of structural part, top of structural part and top.)
Usually, a tile covered roof is defined by the top surface of it's structural frame. It means that if I change the composite (e.g. replace the top : ceramic tiles by slates or replace the bottom: 10 cm bottom isulation by 25 cm bottom insulation) this structural part of the roof should remain at the same level.
The current parameter doesn't give this possibility. So after changing a roof composite, we need to moove it up or down.
Please solve it with the 4 level options that already exist for slabs.
Tinou.
Étienne - AC 24 - France
3 REPLIES 3
Tinou
Lingwisyer
Guru
I believe this is on the roadmap listed under "Idea Pool". Really should be way beyong just an idea given how long this wish has been around, but hey, at least it is there...
There's a public ArchiCAD roadmap right now.
https://graphisoft.com/product-roadmap
You should check there if it exists.
I think this wish is crucial.
You cannot build a line.
