Read more
Wishes
Complex profile as roof edges
jameshowells
Currently (Archicad 26) the roof tool allows modification of each plane, to assign eaves/gable/ridge/valley... etc. and to individually decide how the edges are cut.
In actual construction this is a complicated element and should really be defined using complex profiles.
The issue we have every time is at gable walls.
The roof thickness defines a visible line on the elevation, and the surface needs to be custom made to reflect the roof angle.
2 REPLIES 2
Lingwisyer
Guru
Might this thread from when the Railing Tool was first released help?
https://community.Graphisoft.com/t5/Design-forum/Profile-to-follow-slope-of-roof/m-p/219952
Ling.
Erwin Edel
The 'eaves' etc is only used for schedules, so you can determine the quantity (could useful to know how many m¹ of gutter is needed etc).
In case you were wondering what functionality that currently has.
Until your wish is granted: it isn't too difficult to model most connection by adding 2nd roof with a different composite and using 'merge' to make the floor plan display correct.
We have no issues to generate sections up 1:50 scale without modelling too many extra elements this way.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
