This is something that is not unique to Archicad.
It's inconsistency across tools.
For example, the slab tool has several options for "show on stories", where as a column has those same options, with the addition of "All relevant stories". It doesn't however have "custom", which is available to slabs. The object tool has a different configuration again, while the wall tool only has two.
The object tool funnily enough has the all relevant stories option, but doesn't actually work for all objects...
Now the argument for the above has been, well normally you don't want to see the slab on other stories.
The problem is you do, often you show the dashed outline of a floor above. A foundation plan you would only see the current story.
There are other examples but I'm sure the community is already well aware of them, as can be seen on the forums.
Theres all sorts of workarounds, but really the emphasis should be heres the options, you, as a user of the software can choose how you want to utilise them. Rather than, the developers limiting the use of a tool based on certain presumptions on how it might be used.
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER | LinkedIn | My Top Wishes ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam Perth, Australia and Tauranga, New Zealand Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
