Wishes
Conversion of PlotMaker PMK files earlier than ArchiCAD 8.1
Graphisoft has provided a way of opening old project files (PLN) going back as far as version 4.1 using 'converter' versions of ArchiCAD:
http://www.graphisoft.com/downloads/fileconverter.html?_ga=1.124968590.527701258.1233614224
Yet, the companion PMK (PlotMaker) files can NOT be opened if generated from AC 7 or earlier. This 'orphans' these old PMK files for projects that may yet come to life again for renovation or facilities management. See this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?t=53332
Graphisoft could provide a standalone PMK converter that converts old PMK files to PlotMaker 9 PMK format which is readable by all versions from AC 10 to AC 20.
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
0 REPLIES 0
Learn and get certified!
