2021-11-24 12:37 PM
Hi Everyone,
I checked same of the existing conversations in and around window corner. It seems to me, that it is not possible yet to hendle the two section of a corner window seperately. I meant, they cannot be customazie individually. is it correct? If I am wrong, how can I customize separately? Many thanks in advance.
I tried to select, separately, however any change that I do on one side it applied to the other side as well.
My design goal is to have a corner window joint in the glass, achived, but with a differnt reveal result (my current problem) any advice and/or solution.
Ideally I need also to add a solid panel section (openable) along the long section of the corner window.
Is it possible and/or to I need to treat again seperately with the window tool?
Many thanks in advance to all
Regards
Mariano
Solved! Go to Solution.
2021-11-24 03:35 PM
Hi @Mariano_BAMA , see the my attached images and check if this is what you want to show?
I used the Ribbon Window 16, insert it as a normal window, setup the Corner Connection Type as "Glass" (I don't think any of the latest windows can do this??).
So you can have a frameless corner window and both windows in the corner can have different reveal types as per my image.
2021-11-24 03:35 PM
2021-11-24 04:21 PM
Ps. I hope in the next version of Archicad they will allow to manipulate separately each section of the corner window. It makes more sense.
Thanks again
2021-11-25 03:20 AM
You can if you turn of the corner connection option.
Then each will be a separate window.
You just have to turn on the custom corner and reposition the windows on plan so they join at the corner again.
2021-11-25 07:11 AM
"...manipulate separately each section"
Isn't this is only an issue if you build the window using the Corner Window tool? I have not used it in ages due to previously having issues with it...
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Self-taught, bend it till it breaks | Creating a Thread |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2021-11-25 07:26 AM
Yes, only if you use the corner window tool.
By default the windows are linked, so what you do to one, happens to the other (except for the window length - that is independent).
Turning off the connection is the same as placing separate windows and customising the corner connection.
2021-11-30 01:36 PM
Thanks Barry, for your advise. I will use it next time.
Ps. Sorry to reply you so late.
Thanks again. 🙂
2021-11-30 01:37 PM
Thanks Lingwisyer, to your participation and comment 🙂
