Wishes
DWG Export vs. Import translators should be separate!
Thomas Holm
It would be much more efficient, easier to grasp, easier to manage and simpler to handle if DWG Import and DWG Export settings were always handled by different translators.
Now, it's easy to confuse some options in the translators with each other.
It is of course possible to separate them by hand, but it would be much easier if Archicad always prompted you for an export translator when you're exporting, and for an import translator when you're importing.
The translators would also get simplified and more straightforward this way.
0 REPLIES 0
