Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Wishes
DWG translator graphic override
DavorP
Trying to control how DWG is saved out and having problem with fills - I want them all transparent/not to show. There is a very simple solution with graphic overrides but in this case we need to create duplicate views and layouts for DWG export - a bit inconvenient.
If there was a setting in the save section of the translator to pick a graphic override to be applied, that would make the process very simple and would allow saving the same set of layouts as you would publish to pdf.
BIM manager
0 REPLIES 0
