Read more
Wishes
Display Order Panel
Sabrina
My wish is for a panel that shows elements display order and that it is possible to rearrange the elements in this panel
3 REPLIES 3
jl_lt
Ace
This one would be really nice!!
I would add the ability to create display order groups, to which you can add elements with the same interface as the find and select funtion.  This way, objects that are in these groups always display in front or behind other groups. If you take a specific object out of this groups, you can visualize them in a different order.  Of course, could get out of control really quick
Not taking away from your wish.
I just wanted to make sure that you know you can see the display order when you use Element Information in newer versions of Archicad (I think 25+, could be 24+?).
You can't change it there, but you can see it.
Hi Barry, didnt know that!  not the prettiest way, but still useful
