2024 Technology Preview Program
Wishes
Display order level number of elements
Ancha
Display order number to be manually adjusted through element settings. User would be able to select elements in 3D and change the display order number in order to manage the display order in floor plan and section.
Workflow example: User needs to adjust the draw order of all external walls in every floor plan of the model. In 3D window Finds & Selects all the walls in question and through element settings / selection settings adjusts manually the number of the display order level.
*It would also work the same way as "Relink Home Story" option that is available in 3D window.
Thank you in advance.
0 REPLIES 0
