Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Wishes
Distance Guides Wishes - ( 2 )
Mahmoud Qenawi
A) Wish ( 1 ) :
https://community.graphisoft.com/t5/Wishes/Distance-Guides-wishes-1/td-p/575200/jump-to/first-unread...
B) Walls & Beams :
1) If I can by DG modify only one wall/beam which affecting the whole space by selecting the wall/beam that will be moved and the two adjacent ones in order to keep them connected, eg. stretching a room length or width.
For now I can move one wall/beam by DG and then retrieve intersection by intersect tool, as when I select the other adjacent wall/beam the DG disappear so pls DG don’t disappear.
AC 27 INT 4001 - AC 26 INT 5002 ( For MEP Purposes )
0 REPLIES 0
