2024 Technology Preview Program
Wishes
Distance Guides wishes - ( 1 )
Away from discussions about the Road Map & away from things don’t work normally in Archicad, I thought that better to wish for a stronger DG to move from being an experimental feature to a real one as soon as possible.
A) Grids :
1) If  I can create axes with the help of DG.
2) If I can create diagonal axes with aligned DG.
3) If I can modify only a distance between two axes which affecting only one axe by selecting it only.
4) If I can modify only a distance between two axes which affecting a group of axes by selecting the whole group to let them move together without changing distances between them.
You’re welcome to put your thoughts in this topic we may be able to help Archicad development team to change & perform as users’ needs, thx.
AC 27 INT 5030/WIN 11
0 REPLIES 0
