Read more
Wishes
SOLVED!
Distinguish the accuracy of calculations by how the result is displayed in Schemes
gap
As described on this post:
https://community.graphisoft.com/t5/Project-data-BIM/Accuracy-of-calculations-and-display-units-in-S...
Calculations of quantities and other properties must be made according to the precision defined in the Calculation Units menu, as is already done. But we must have some way of choosing the decimals in which the calculations will appear in the Schemes, regardless of the decimals used for the calculations. Perhaps this could be done through Dimension Styles.
archiCAD 26
1 ACCEPTED SOLUTION
Solution
gap
I found a solution for this, as I describe in the mentioned post.
archiCAD 26
1 REPLY 1
Solution
gap
archiCAD 26
