Read more
Wishes
Door Details, Casing
Brad Norris
It would be wonderful if there was a way to create custom profiles for door casing.
4 REPLIES 4
Lingwisyer
Guru
Identical wish from 2014
Wish: Custom Complex Profiles for Door/Window Jambs
Wish: Doors & Windows Enhancements
David O
Yes I totally agree, the majority of my work is interior design & I end up having to add separate architraves, there should be options for plinth blocks & architrave blocks as well
Tim Ball
Maybe the frame and architrave profiles could be similar to curtain wall elements and railings where you can create your own profiles
Tim Ball
AC26, iMac
User since V5
tcurtis
Agree!  I end up using profiled beams and columns to make my casing.....labor intensive to do for each door.  And if a door moves or changes size, I have to update the beam / columns.  If I could simply choose a profile for the casing it would be amazing and a huge time saver!!
