Read more
Wishes
Double click to delete nodes
Mats Knutsson
Double click to delete nodes would speed up editing.
4 REPLIES 4
kmitotk
That would be nice. For now, you can delete a node by clicking and dragging it to nearby node.
Kei Mito
Architect | Graphisoft Certified BIM Manager
ArchiCAD 26 & 27 JPN USA & INT | Windows 10
Lingwisyer
Guru
More versatile would be a new pet palette option for "Straighten". Select option, click on second node and it would remove all nodes inbetween.
At the moment, I often end up using the Add to Polygon option to create a single new external node that encompasses a number of others inoder to only have one node to delete...
Yes there are many improvements that could be done concerning general editing. I like your "straighten" command :).
The method you suggest with Add-to is good for closed polygons (fill, slab, mesh etc) but not for lines.
I use Add to Polygon a lot with terrain meshes where I have detailed iso curves and want to flatten out areas for construction.
Benjamin Dani
Hello,
Thank you very much for your idea!
This would be a great addition to Archicad so I made an entry under WISH-13202. I hope it will get implemented soon!
Best regards,
Dani Benjamin
Technical Support Engineer
