Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Wishes
Dual Swing Door with sidelight windows
TSarborsouth
When using the door object with sidelights, if you want the door to swing to the interior the window is always backwards. There needs to be a feature that allows you to specify which way the door swings. Only fix is to use a single door and window and "gang" them together.
Doors don't always swing out, why is that the assumption?
AC9-26 V.4034
0 REPLIES 0
