Wishes
Editable-polygonal-outline “Lesene” window
Ignacio
I wish there were a Lesene-like window object with an editable polygonal outline like the Opening tool. A “relief”, “raised panel”, “raised shape”, window object.
[I think I remember that back in the days one could make a relief panel by using a negative value on the Niche window object; that is not possible in AC25, maybe that possibility disappeared when Lesene appeared; an editable-outline Niche would have been nice too, but the Opening tool does that job already; so the possibility is missing for raised shapes only. Unless I am missing something, which I may well be.]
0 REPLIES 0
