Read more
Wishes
Elevator / Lift respect original storeys from Hotlinked file
Jakub N
Dear Developers,
we had severals discussion with Archicad users in Czech Republic about Elevator object (also following this discussion ). It would be nice to have Elevator object which respect original storeys setting from Hotlinked file or which can turn off connection to the storeys and has only Own storey.
When you try put several files with different storey settings and elevators to one big file original elevator are changed depends on host file storey setting. The only way how to do it is make elevator for each storey which is very time consuming and complicated when you want make some changes.
Elevators are current element of almost all building. It would by fine to have professional tool how make them in Archicad.
Best Regards,
Jakub Nohejl
0 REPLIES 0
