2024 Technology Preview Program
Wishes
Expression in building material proprety
Ahmed_K
It would be helpfull if building material propreties can accept expressions inside,
Now it's noy possible to ctrate a proprety for building material with a formula,
This can help in cost calculation especially
Archicad 27
Windows 11 professional
6 REPLIES 6
I ran into similar issue, this seams to be big limitation at the moment. How did you manage to solve cost calculation?
I hope maybe python will have some access to parameters / schedules so this could be solved.
Ahmed_K
To calculate cost, i made an excel file inspired from the "contrabim cost template"
I create 2 propreties
1- unit propretie
2- cost per unit propretie
The rest is done on excel, i export the schedule and link it to excel, so the cost table updates continiously
You can check contrabim youtube channel and website, they put a small file for demonstration, it certainly inspire you !
Archicad 27
Thank you for your reply, I have seen contrabim and indeed it looks quite powerful, however this simple task should be native in Archicad, we should not be obliged to use excel or any other software. If I change something in the model, I would like to have information how it affected cost, that should not be that much trouble to find out. I do not see any logical reason why expressions do not have full capacity for building materials.
Ahmed_K
yes it should be a native archicad functuinality , but, lik it is now, it's suitable for more cusumizable take offs,
for exemple,
here in my country , we calculate wall quantity sometimes per lateral surface, sometimes per linear meter,
it would be better to extract both of the quantities and export to excel and it do his job, you choose which unity you want to use there and voila !
if it was inside archicad, it's possible too, but with some workaround and i tested it
you create a formula propretie , the formula uses the IF logical fuction,
So, if the unit is m², then surface x surface unist cost, If the unit is m, then legth x legnt unit cost
Surface unit cost and legnth unit cost are proreties too,
so you'll end with a ton of propreties to do just simple tasks, and this would be furious especially for young users
Archicad 27
Thank you for your explanation, I managed to create a similar workaround in excel as well following your advice.
JSN
Still not possible by today I guess?
