2024 Technology Preview Program
Wishes
Find & Select - Home Storey
DGSketcher
Legend
The F&S - Positioning options should include "Home Story" to help find displaced elements that are at the correct height but assigned to the wrong story or appearing in the wrong view.
3 REPLIES 3
mija
I believe F&S should have same options as schedules, especially Library Part Parameters.
Archicad 26, build 3001
Montenegro
Jonas Krieg
Hello DGSketcher
Yes, I agree. But there is a workaround, if I understood correctly what you need:
Add an Archicad property expression, where you put the "Home Story" name or number. You can then use this property in the "find & select" dialogue!
Jonas
ArchiCAD 25 5005
MacOS 11.6.3 / MacOS 12.3
DGSketcher
Legend
@Jonas Krieg Thanks for the suggestion. There's another way which is to assign a GO to highlight things on a story, but I was troubled trying to find an elusive 2D object on plan which doesn't always highlight as well as 3D.
