2023-03-08 12:21 PM
Hello together,
the option t tilt wall is already long time onboard...
Just I realized that the top-view of connection with vertical walls is wrong.
In 3D everything o.k.:
... but in the floor plan, we get this:
So please could you fix that, this way:
2023-03-09 03:21 AM - edited 2023-03-09 03:21 AM
That is odd.
When I try in 25 it seems to work just fine.
2023-03-09 12:15 PM
You've a cut view, not the top view – right?
2023-03-10 04:07 AM
I was just showing the 3D view and the floor plan (which you said was wrong?).
2023-03-10 12:14 PM
Only 😁 the top-view in the floor plan is wrong...
... from time to time we need such view...
2023-03-12 06:14 AM
What do you mean by the 'top view in floor plan' ?
The floor plan is a top view.
Are you using 3D Documents?
2023-03-13 09:14 AM
Is it really so hard to understand what I mean?
Do I maybe use the wrong expressions... because English is not my mother tongue?
Could somebody help here?
2023-03-13 09:31 AM - edited 2023-03-13 09:32 AM
Language can be a problem.
You mentioned a 'top view' of the walls - I am unclear what you mean by this.
Then when you show the image you mention "in the floor plan we get this".
In the floor plan I have no problems - it appears to me as you said you wanted it.
Here are 2 inclined walls and 2 vertical walls.
All the same heights and shown with 'Projected' floor plan display.
If this is not what you are seeing, then the challenge is going to be making sure we are both talking about the same thing.
2023-03-13 02:24 PM
Just have a German version available right now...
Writing about these expressions...
2023-03-14 03:39 AM - edited 2023-03-14 03:40 AM
Yes I believe we are looking at the same things.
Is it anything to do with your Floor Plan Cut Plane settings?
