2024 Technology Preview Program
Wishes
GDL Object editor - Live 2D/3D Graphical editing
owen
another one:
it would be good if the 2D/3D Views allowed you to test an objects graphical editing directly in the editor rather than having to save, switch back to AC and test an object placed on the floorplan or in the 3D window.
I think this would require an additional column of debugging parameters as has been discussed elsewhere so as not to modify your objects default parameters when doing this (and a button to reset debugging parameters to defaults).
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
1 REPLY 1
F Barradas
It's 2024 and this is still an absolute necessity. For reference, see how Vectorworks handles Hybrid Symbols (even though Vectorworks allows you to add / edit multiple 2D projections, in Archicad a single 2D plan view should be enough).
