2024 Technology Preview Program
Wishes
GDL parameter name translator
abdelaziz
it would be nice to have an option that would automatically translate the parameter names of GDL objects in one click
AMD Ryzen 5950x
AMD RX 6750xt
AC27
3 REPLIES 3
runxel
Legend
By translating you really mean from one language to another?
E.g. from french to german?
Seeing the "quality" of Google translate I'd guess that this will never work 😉
The used terms are way to specific and you would lose meaning all the time. In the end you end up faster by just doing it by hand.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Hi
if this option is possible through a Python script or other automation script, and I have to manually change 20% or 30% of the technical terms of the parameter names, then I would be very satisfied
AMD Ryzen 5950x
AMD RX 6750xt
AC27
Well, certainly this is possible.
But do you really need this so often you would actually benefit by having a script?
But yeah, the outline would be like:
  • Let the script convert the GSM to HSF
  • Open the 'paramlist.xml' and substitute all Names by the translation
  • For this you can use the API of a translator of your choice (costs will probably very low since the volume is low; maybe even free of charge)
  • Let it convert back to GSM
This is about 100 lines of Python code, I guess.
