2024 Technology Preview Program
Wishes
General Board for Fill, Building Material, Composite, Surface
i wish GS can combine 4 setting dialog for Fill, Building Material, Composite and Surface to One.
that very important for setup new material, composite...for document by Automatic Label by properties as: Cut Fill, Surface or Building Material.
Many Thanks developer
2 REPLIES 2
Lingwisyer
Guru
Or at least make them floating windows so that you can open and modify some / all of them at once.
Ling.
concepsys
For many years, I find this one of the major flaws on Archicad menu design.
To define a material, many times we need to configure pens, fills, surfaces. So, why not have a tabed window that allows to pass from one configuration to the other without having to open the pens configuration window, then close it, then open the fills configuration window, then close it, then open surfaces configuration window, then close it to open materials window?
You see how long it takes just to configure a material?😅
