Wishes
Gravity to Mesh/Slab/Roof/Shell Association
I work for the San Diego Zoo and do all our Schematic Design in ArchiCAD. As such we have large sites with allot of landscape elements (plants, trash cans, Benches, Stairs, handrails, play elements) that I place on the mesh using the gravity tool. The thing that frustrates me is as I continue to develop the site plan and move contour lines to fine grade the site the objects remain in the original location. What I wish is that a library part elevation can be linked to the object the same way the elevation marker is linked so as I change the contour elevations all my plants, site elements will follow the referenced surface. This association would save me so much time in adjusting elevations of objects after we adjust the site for ADA slopes and fine grading through the rest of the design process.
4 REPLIES 4
Not really an Archicad discussion so I moved this post to the wishes forum.
Versions 6.5 to 26
Chris,
I was wondering if this adjustment in element elevations could be achieved using the Grasshopper-ARCHICAD Connection. You would know where each object is, you could get the top surface of an ARCHICAD Mesh in Grasshopper, Grasshopper could calculate the Mesh surface elevation at the position of each element and reposition the elements to be located on the surface of the Mesh.
This is theory, but GH-AC may be able to do it.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
alemanda
well ... actually I think the tecnology is already there. Levels - associated to a mesh as well as those ones associated to slabs - updated automatically so what we only need is just a "link" between objects/elements ... such as "linking tecnology" would enhance the BIM Spirit of the programa and speed up certain routine operations.
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
This is an essential tool, and it could be combined or complemented with a "follow the mesh" tool that I posted here. https://archicad-talk.graphisoft.com/viewtopic.php?f=25&t=62474#p286735
alemanda, I must disagree with you. The problem is that this works only in a flat scenario. When the project has even a slight hill, the walls, slabs and etc won't be in a exact level, but somewhere inbetween them, and they will partially float over the mesh or stay buried and even if both mesh and object are linked to a floor, if you modify a level line of the mesh they will still mismatch, because only its base is linked to a floor.
