Wishes
Hide Building Material Individual Edges on Complex Profiles
I would like to be able to hide Building Material individual edges on Complex Profiles... With this, I could made a CP to perfectly cut the continuous (single slab to all rooms) recessed ceiling. No need to hide SEO operators. Just a strong Air BM inside the CP with hided edges.
Right now, this is what we got:
It would also be useful in this situation.
2 REPLIES 2
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Braza,
Thank you very much for sharing your wish!
This would be a great feature if it is done properly. I entered the wish into our Wish List database (please refer to it as #12933). Hopefully, our Product Management team will consider implementing this one in the future.
Thank you once again, and I wish you a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Thank you Minh. Much appreciated.
The thing is we already have control of edge visibility in sections... If we could extend this to 3d would be great.
Perhaps if you set two edges as invisible, the node between the two would be invisible in 3d.
