Wishes
Hotlink Manager issues
Hotlink Manager is horrible probably beyond repair, but it would be a bit less upsetting if:
- it showed the control layer ('insertion' layer, whatever) for each module instance;
- when you hit 'break link' and the control layer is locked, it somehow warned you that the control layer needs to be unlocked instead of just not breaking the link and not warning you.
0 REPLIES 0
Learn and get certified!
