Read more
Wishes
SOLVED!
How to change color of layer
cocoloco
How to change color for layer only? I found to do it is to change set of pens... but too complicated. Is there easy switch to change colors for layers?
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
1 ACCEPTED SOLUTION
Solution
Layers in Archicad do not have colours assigned to them.
Each element has its own colours.
As Mahmoud suggests, the only way to control it by layers is to set up a Graphic Override to override the colour of specific or all elements in a specific layer to the colour you want.
2 REPLIES 2
Graphic Override rules can help you manage that issue by adjusting all element types or a specific element type in that layer to be presented in the chosen pen color.
AC 27 INT 5003/WIN 11
Solution
