Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Wishes
I would like to turn off the selection of edges of the slab in the floor plan.
I don't know if it's my fault, but even if I try to use the Slavic boundary,
In the case of stairs and SEO, this line needs to be turned off, but it cannot be turned off, so you may have to turn off the entire SLAB and draw the line.
Even when anti-condensation material is used in the lower part of an apartment, it actually appears, but there is a line that is not shown in the drawing, so it has to be partially turned off.
And since there are many cases where it doesn't seem to turn off with number 19, I hope you can turn it off with number 0 or a Hidden segment.
AC25 5010 / AC26 4019 on window 11
1 REPLY 1
Rve
Not only for Floors in floorplans but also in fills.
it would be great to have boundaries with different linestyles. Also an invisible one (or white one).
