Wishes
Implement V-Ray SDK into ArchiCAD to enable seamless V-Ray rendering
rvto
(Jeju Airport, Rendered with V-Ray, by Tomek Miksa, from chaos.com)
I have searched for a long time how to efficiently render projects in V-Ray. There exists no such thing through ArchiCAD right now.
The best ways are either using a intermediary software, such as Rhino, 3DS. Or model using another software, i.e. Sketchup or Revit.
i have viewed some topic on the matter and there seems be quite a demand for this. Also, Chaos is open for any collaborations.
To those in charge, what are the chances I (and others) can see this be implemented into ArchiCAD, in order to seamlessly render as through Sketchup or Revit?
open invitation from Chaos:
https://www.chaos.com/developers/3d-design-cad-software
2 REPLIES 2
Eduardo Rolon
Not to ignore your request for direct implementation.
The best existing workflow for VRay is to use Din3D (https://din3d.org/) to "link" AC to either C4D or 3DMax since changes to the model in AC can be updated without having to reapply materials etc.
Eduardo Rolón AIA NCARB
AC26 US/INT -> AC08
another Moderator
Thanks for pointing that out.
Still what I said applies, there is no way to do this except with intermediary software.
Which is just additional unnecessary cost, since it only functions as a translator.
This is not a solution to the problem.
