Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Intersect SEO command with more than one operator
The Intersect command of the Solid Element Operations must work with more than one operator. It must be able to intersect several targets with several operators.
At the moment one operator can interact with many targets, but two operators cannot interact with one target.
This feature is a major shortcoming of the SEO command. It requires a lot of extra work to circumvent and in many cases it is impossible to achieve the desired result.
Marton Kiss
Thanks for sharing this. I've posted a feature request about this, so our designers will consider this when the will look for new features to be developed.
Regards,
Marton
Marton Kiss
VP, Product Success
GRAPHISOFT
Thank you for your response, Marton! We'll keep our fingers crossed!
