Wishes
It should be possible to completely hide elements with graphic override
Ro-Ra
Currently the only way to hide elements are with layers and renovation filters. Being able to do so with graphic overrides would allow for limitless possibilities when interacting with parameters. Ideally it would be a checkbox at the top of the window which would disable all other graphic override settings.
Maybe another setting about collision interaction if the element is completely disabled you might want to disable interaction between walls/slabs?
1 REPLY 1
neilmcallister
Absolutely.  I was surprised to find you couldn't do it.  The best I have managed is a transparent fill and a dotted outline with a large dot spacing and a fine white pen.
Archicad 26 / Windows 11
Learn and get certified!
