Read more
Wishes
SOLVED!
Keyboard shortcuts for the pet palette
Juan Manuel
Will it be possible to put keyboard shortcuts to the slab or frame editing tools, etc.?
1 ACCEPTED SOLUTION
Solution
JaredBanks
Mentor
F and opt+F are next and previous pet palette items. Similarly G is next geometry method in the info box. Both are SUPER helpful keyboard shortcuts.
Jared Banks, AIA
Shoegnome Architects
Archicad Blog: www.shoegnome.com
Archicad Template: www.shoegnome.com/template/
Archicad Work Environment: www.shoegnome.com/work-environment/
Archicad Tutorial Videos: www.youtube.com/shoegnome
2 REPLIES 2
Not for adding nodes or stretching edges, at least to my knowledge, but you can map drag, mirror, multiply, adjust, split, elevate, rotate,
Solution
JaredBanks
Mentor
Jared Banks, AIA
