2016-06-02 08:14 PM
2023-04-05 08:33 AM
have been facing the same problem, has anyone found solution for this?
2023-04-05 08:45 AM
The leader connection is only to the side of the text (left or right depending on how you place the label).
If you rotate the label 90°, you will find the connection also rotates.
But if you want horizontal text, the leader connections will also be horizontal.
2023-04-05 10:57 AM
Thanks Barry.
It would be good to have centrally aligned vertical leader connection in label with horizontal text.
